It does not make sense though...why would the noise stop if I engage the clutch?
Why is the noise not apparent as soon as I drive the car, it has to warm up to make the noise?
Originally Posted by RandallNeighbour
Did you replace your caliper bolts when you removed them?
They stretch when torqued down and should be replaced each time they are removed. This could be the cause of your clunking.
-Cesar
03' 986 Midnight Blue Metallic
_____________________________________________
Gemballa Lowering Springs | 18” Carrera Light Wheels | Painted Calipers
14/18 H&R Spacers | Aero Wing & Rockers | Powder Coated Exhaust
Creator of CRIOS exhaust mod | De-Snorkeled | De-Ambered
Light Weight Flywheel | Tinted Windows and Windscreen
Painted Bumperettes | 550 Spyder Grille Kit
http://lh5.ggpht.com/_9sTq_sN1KDw/Si...2009%20055.jpg
