Well I hope having a 2000 3.2 with a steel rest pad rather than plastic will keep me a bit safer than most!
Nice idea with the rollers! One has to consider the chain shape produced with them especially the speeds we are talking about; I would guess flat would be better. Any bearing dia that small is going to be doing some wicked rpms assuming no skidding/wear; one will need to ensure strength/lubrication at these sites...increasing the bearing dia will weaken the the arm at points; all in a limited space.
From what I can see the LN arm has a greatly increased web area which would give increased strength. I am surprised the Porsche arm fails as it has. It must be a combination of poor castings or choosing to put a casting where one shouldn't and shock loading resulting from the rest pin failling......just a guess without seeing the set up of the engine
