Originally Posted by stateofidleness
this all started within about a month.
tonight on the way home from work, i threw another code (only 1 this time)
p1128 which looks like a rich threshold on banks 1-3
I believe if you look for a vacuum leak, you will be looking in the wrong direction.
I believe that this code is going to point more in the direction of the two O2 sensors on that bank of the exhaust going bad.
When the exhaust passes through the headers and past the O2 sensors, the computer receives a signal that tells it if there is or isn't alot of Oxygen in the exhaust. If there's too much Oxygen, then the computer richens up the mixture. If there's too little, then the computer leans out the mixture.
Right now, the O2 sensors are saying that the one bank is running too lean, and the computer can't richen up the mixture for that bank any more than it already has, hence the CEL being lit.
If you replace those two O2 sensors, that will most likely resolve the issue.
Some recommend just replacing all 4 at the same time for the best results.
BC.
