Thread: sigh.. CEL
Old 10-19-2009, 08:08 AM   #22
Daniel R
I have had all the same fun and games you are describing with my 2000S. It turned out to be an MAF on the way out and a pair of oxygen sensors in a really bad way, one so bad that that bank was bringing up misfire codes. When I replaced both the MAF and O2 sensors it was back to normal.
On a side note, if your car has been doing this for some time you may want to check the catalysts for damage. I switched to bypass pipes when I replaced the sensors as it was a less expensive option than new cats. I am now catless, as in Australia we only have to run one set of cats so the Boxsters only have the main cats and one set of O2 sensors.
Good luck.
Daniel R is offline   Reply With Quote
