Old 10-12-2009, 07:36 AM   #5
Bladecutter
Originally Posted by Lobo1186
thanks for the input guys. this guy has statefarm i wonder where they will make me take it to get looked at.
That's not the way it works.
You take it to where ever it is that you want to take it, and then send them the bill if there are any damages that need to be repaired.
The first place I would take it to would be an alignment shop.
Have them put it up on the lift, and see if the alignment is still in spec, or if it was knocked out.
If it was knocked out of spec, then can they put it back into spec.
If they can, then the guy only owes you for an alignment, and for the wheel repair.
If they can't put it back into alignment, then the shop needs to determine what is causing the alignment to be out, and the guy gets to pay for all that work, too. Could be damaged control arms, wheel bearing, ball joints, tweaked frame, etc.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
