Old 10-11-2009, 05:18 PM   #2
Jaxonalden
Jaxonalden's Avatar
Yo bro,
Adjust your mirror all the way to the inside so the outside edge is sticking out. Now grab the mirror edge and pull it out. The mirror glass is mounted with a circular plastic clip and it takes just a steady pull to release it. If your car has heated mirror's there will be a wire to disconnect before you can free the mirror and troubleshoot the reason for the mirror to become loose.
Let me know your findings, if you find your mirror mounts are non-repairable (plastic clips are broken and won't remount securely) I might be able to help you with a replacement mirror. I changed my original with a factory convex for better blind spot awareness. It's now gathering dust up in the shop.
