Installed the AOS today. It had it's moments.... As many have reported, I used a standard automotive "o" clamp vs. the factory spring clamp. Much easier...
Anyway, we will see if the solved the issue I am seeing where the lower right rear area of the engine bay is covered in oil. If it is not the AOS, I think it could be the rear part of the valve cover that is leaking. We will see.
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
