Old 09-25-2009, 01:59 PM   #1
BobMarley1
It rattled up or down. Your window might be loose, that was the first thing I was checking for. There are 2 easy ones you can check. Under your doors, there are 4 black oval covers, remove the 2 inside ones, there you will see some nuts, tighten those. If that is not it, search the forum, and look for 2 spots on the door to tighten the window when it's in the down position. I JUST deleted the links I used, and can't find them. I still have this link, it shows how to take apart the door panel, really simple, less than 4 minutes to take it apart.
http://images2.wikia.nocookie.net/boxster/images/b/b6/Boxster_speakers_update_article.pdf
Don't tighten too much, you will shatter your glass.
If that's not it, check your door speaker, like we said, the screws were totally out.
it's the black thing inside the door, once you peel back the protector sheet.
lmk if you have any questions I'll try to help.
Originally Posted by Alex Walker
Wait, so before when you closed the door would you hear a rattle sound? I'm having a similar problem on my passenger side door, but it's only when the window is down. Obviously it's the glass but the service guy at the dealer had no clue.
'02 Boxster Seal Grey or is it Gray?
-Alexandria, VA-
BobMarley1 is offline   Reply With Quote
