Old 09-24-2009, 12:58 PM   #1
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by idheaton
The mounting is different between the 5 and 6 speed transmissions so you will need an adapter to fit an s-muffler to a 5-speed transmission.
Well actually.... The 97-99 Boxsters had a different mounting method on the top bracket of the muffler than the 2000-2004 Boxsters- so yes, if you bought a 2000+ muffler to fit on your pre 2000 car (whether it was a base or S muffler), you would have to buy the adapter bracket to make it work. However, if you have a base 2000-2004 boxster, and wanted to fit an S muffler of those same years, they were interchangeable, and no modifications are necessary to fit an S muffler to a base car.
