CV boot
Check out the DIY forum on this site. A fellow owner explains how he replaced his boots. AZ******************************** has replacement boot kits on sale for less than for around $11.00 each. The kits contain a new boot, 2 boot clamps, a spring clip, and a spacer plate. It takes 4 kits to do both axles. You will need a cv joint clamp pliers, and a large socket to remove the axle nuts. Unfortunately it will be cold and snowy soon. Winter is a good time to do a project like this, since there is no pressure to take the box for a drive in the snow.
