Thanks for all the opinions.
I figured and get a few more opinions and asked the same question on the grassrootsmotorsports forum.
One poster had a very good point, I quote:
"If you are using non DOT rated harnesses and your kid gets hurt (God forbid) then you will be seeing the wrong side of a court room real quick."
So I am sticking with the stock seat.
However I since detached the seatbelt buckle (the one which deactivates the airbag) from the Britax seat, so that I am no longer stuck with this seat and I can look for and use a better fitting child seat instead of the ill fitting Britax
