Old 09-11-2009, 11:01 AM   #13
Kirk
Originally Posted by Topless
I am a fan of forced induction...just not really on these cars.
I think you can do it, I just think the quality of the tuning and parts in the kits that have been available have been sub-par. On the 996 side VF Engineering has sold over 500 of their supercharger kits that run a mild 6 psi. People are tickled with them and they seem very reliable. But VF does it right. They supply larger fuel injectors and have the ECU reflashed with a custom GIAC tune. I think that's the real key here is that they had an industry pro like GIAC tune the thing.
TPC used a 7th injector and a Uni-chip piggy back ECU for their 996 supercharger kit and now they've followed suit and switched to using larger fuel injectors and a custom ECU reflash like VF.
Based on what I've read the IA and TPC installs were crap and yes tuning was an issue too. Just look up Gary in BR's dyno chart comparing his IA setup to his TurboWerx setup. The IA supercharger was making almost nothing over stock!!!
It looks like TurboWerx might have things right with the current Boxster S turbo kit they sell - low pressure (like 5.5 to 6 psi) turbo with larger injectors and a custom ECU reflash. If their tuning is good (and that's a big IF) that should be good for a reliable 100 HP, which is what they claim. If the 996 and VF Engineering guys can do it reliably with the 3.4 and 3.6L engines, then we should be able to do the same, if not more, with the 3.2L which is theoretically stronger!
Kirk
2000 Boxster S - Gemballa body kit, GT3 front bumper, JRZ coilovers, lower stress bars
2003 911 Carrera 4S - TechArt body kit, TechArt coilovers, HRE wheels
1986 911 Carrera Targa - 3.2L, Euro pistons, 964 cams, steel slant nose widebody
1975 911S Targa - undergoing a full restoration and engine rebuild
Also In The Garage - '66 912, '69 912, '72 914 Chalon wide body, '73 914
Kirk is offline   Reply With Quote
