Thread: Serious Problem
Old 09-04-2009, 03:36 AM   #6
Lucky
Originally Posted by Viper5
Havent started it since im afraid of all the fuel pumping in could have flooded something. If it was the fuel pump, would it be safe to start it? I dont want to do something irreversible. As far as turning power on, just reconnecting the battery does weird stuff without the use of the key. The key itself is fine and just turning on power seems to be ok.
Fuel pump just pressurizes the system... only if the injectors open does gas "flood" the intake/engine. I think you are fine to start it, but with that electrical weirdness I wouldn't go far!!! Like stay within "pushing distance" so you and your roommates can push it back into the garage.
Go advice on the ignition switch... if you DIY it will cost very little. IIRC, part is about $40.
Good luck!
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
