Old 08-29-2009, 10:02 AM   #2
Jake Raby
Engine Surgeon
Originally Posted by jmatta
The very first issue that springs to mind about trying to do that conversion is the fact that there isn't much airflow around the engine in the middle of the car.
I believe that if you attempted that swap, you would cook the engine on the first drive.
It's true, they are called "air cooled" but in reality, the engines are oil cooled. I think a big challenge would be locating the oil coolers/oil tank and running oil lines in place of coolant lines. Not sure about height, but you are correct, 3.6s have been transplanted into 914s so perhaps that would not be an issue.
We need to get Todd Holyoak on this one!
Absolutely not! The engines are AIR AND OIL COOLED...
I have been developing cooling system enhancements for air cooled engines for over a decade and have done several studies on the relationship between oil cooling and air cooling.
You can cool the oil of an air cooled engine all you want and the cylinder head temperatures won't fluctuate more than 5%... You can't cool the oil and expect that to cool the heads..
