Old 08-20-2009, 09:13 PM   #13
sb01box
Originally Posted by Brad Roberts
Not sure I follow your question? but.. When you go to the GT3 bar up front? it requires shorter length links or the GT3 style "collar" lengths.
B
sorry I should have been more clear. this thread started with conversion to M030 suspension parts. my understanding is that the parts (sway bars) are basically the same geometry as standard boxster pieces, but stiffer.
in browsing through the 986 catalogue, the factory drop links are the same part number for the front and the rear (left right is different).
my question is/was if i'm just replacing the drop links and not the sway bar, can the same length (Design911 or Tarett) drop links be used for the front and the back.
thanks in advance.
sb01box is offline   Reply With Quote
