Old 08-19-2009, 02:43 PM   #14
ddb
www.klisstle.com
ddb's Avatar
Originally Posted by Lil bastard
It's not unheard of to lose an ancillary bearing (waterpump, alternator, PS pump, AC compressor, idler pulley) after swapping the drive belt.
Ain't that the truth! I recently replaced my water pump (81,000 miles). It had started leaking but I changed it prior to it grenading fortunately. I also replaced the coolant, added a 160 degree LN thermostat as well as a new serpentine belt. While the belt was off I inspected the pulleys and found one of the two idler pulleys a little loose. So I replaced both idler pulleys and the tensioner pulley. When I put it all back together and started it I heard a new, abnormal sound. Turns out it is my alternator pulley. I'm about to replace it in a few minutes and will detail the procedure in a new thread for future reference.
BTW, I saved a small fortune getting my parts from Sunset and doing the work myself.
ddb
