Old 05-15-2005, 07:01 PM   #1
tqtran
tqtran's Avatar
Originally Posted by eslai
6. The top controls are a bit annoying. It's a one-touch up/down button IF the car is moving. If you do it when the car is not moving, you have to hold the control down for the entire operation. If you let go of the button, the top stops moving and the computer warns you that the top isn't fully closed or retracted. If you push the button while driving, it starts moving but then if you pull up to a stoplight, it stops.
Why? Why!? What use would I have for opening the top halfway? It should ALWAYS be a one-touch button. If I want to stop it midway, I should be able to push the rocker switch in the other direction to stop the motion.
ummm...let me see....to do an oil change or engine service perhaps!
THe "halfway" position is the "Service position" It is needed to access the engine.
With a "one touch" all the time, it would take you forever to time the service position correctly.
tqtran is offline   Reply With Quote
