Thread: Dash speakers
Old 08-03-2009, 05:20 PM   #1
urban_legend
more on the dash speakers
The speaker grill has two parts - one looks like it should be over a seperate tweeter but when you remove the grill there is no seperate tweeter.
Two main ways to replace the speaker:
- use the special speaker bracket sold on EBAY
- or do as I did and just use the existing speaker basket. You will need to cut out the OEM speaker and just use the plastic. The plastic basket (now a plastic ring) can then just be screwed back into the speaker grill keeping the proper speaker orientation.
You will want to use a 4" speaker that you can break the mounting tabs off - you won't need them and they will just be in the way. External dimension should be less than 105mm to fit back into the plastic ring. The Kappa 42.9I (2-way) were 100mm external and were just a few mm shy of a perfect fit..so I needed to add a gasket to tighen them up.
Regardless of the method choosen you will need to use a 4" speaker otherwise it will not mount to the speaker grill. Also keep an eye on the speaker depth - for a good reference see the Polk 4" dB dimensions they will fit fine.
urban_legend is offline   Reply With Quote
