Old 05-14-2005, 02:10 AM   #1
clubhead
Originally Posted by stunt
ok when i take the car the indicator is always full, after ten minutes appear the really level of gasoline...
I don't understand how is the problem, i think i need to access the tank do you have same instruction to access the tank?
Thank you
I've asked this before at renntech.com. The fuel tank opening is located under the batt. You need to remove the batt and the plate underneath it. You should be able to see it once you've done that. This is only to access the fuel tank opening where the fuel pump is though..... not to remove the entire fuel tank.
clubhead is offline   Reply With Quote
