Old 07-31-2009, 12:17 PM   #1
Oaktown 986
Originally Posted by RandallNeighbour
MIMA: before this thread gets too far off topic, let me say I think you should put that cash in the bank and wait a full year to do anything to your car.
It is highly likely that you will incur at least $500 worth of repairs in the coming months. Older boxsters need MAF's, O2 sensors, a control arm, an air/oil separator, a coolant overflow tank, a radiator fan, an instrument cluster, the AC head unit, and on and on the list goes.
Unless you have meticulous records from the PO showing all this and more being replaced, it's not a wise move to bolt on shiny bits to the car when important mechanical items will be needed in the near future with regular use of the car.
I agree: I'd also like to add that as your aging components start failing.. which will happen sooner than later, you can replace them with well-matched performance parts. But the overall performance of the 986, even early non S models, is very spot-on from the factory.
Jon
Jonny Wonder
1999 Porsche Boxster 5 Spd
Stock, with GAHH A5 Glass top.
Previous Toys:
2005 RX-8, RIP
1989 GTA, 5 Speed, Procharger Supercharger and 2 Core Intercooler, 1 3/4" headers, 3" Flomaster Exhaust, cat-delete, digital ignition, bigger fuel injectors
Oaktown 986 is offline   Reply With Quote
