Old 07-28-2009, 09:43 AM   #1
mylamb
Originally Posted by BoxsterLewis
Drove it again this morning and it still wont go into 2nd without pushing slightly towards 1st then itll go in. Ever since i had the car it sometimes slightly grinded going into 2nd if i didnt slowly shift or fully engage the clutch. If the synco is going bad is that costly to fix??
That all depends on how badly it has been damaged. You should try and have a shop look at it. If you JUST need synchros and the gears are fine, then no, synchros themselves are not expensive. If you've started to grind the teeth down on 2nd, then that's definitely pricey. The biggest expense is R&R and cracking that thing open to replace what's needed. Transmissions are a labor intensive job. For the most part, the parts are not outrageous. I had this problem - it was a pain to get it resolved but it seems to shift fine now. I don't know much about our motor mounts.
http://farm1.static.flickr.com/169/4...c84611da_m.jpg
Induction howl is easily worth the cost of admission...
2001 Boxster S
Arctic Silver /Black interior
Desnorkled then REsnorkled (planning on Revo flash & prob B&B Exhaust)
mylamb is offline   Reply With Quote
