Old 07-28-2009, 08:01 AM   #3
Adam
Few more questions to...did it do this only once or is it all the time now? Does it grind as well or simply not go into gear? I'm still leaning torward syncro or like SD said possible a failed motor mount. As you suspected, it doesn't sound like a cable issue but it might be worth checking and adjusting to see if that helps before you take it in to a shop.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
