Old 07-27-2009, 10:22 PM   #1
Jake Raby
Engine Surgeon
None of the data has been posted, and it probably won't be... As soon as I mentioned it arguments began and thats something that I simply do not have time for these days.... Plus lots of people are rating the exhaust systems on sound and weight, and all I care about is RPM range and net power, especially torque..
I continue to gather data, I just finshed this testing today... 3 engines, same car.
All started life as a 3.2, the control is the lowest output run.. The 247HP run is a stock 3.2 bottom end with a nice valve job, bump in CR and cam timing alteration... Its got A LOT more left in it, it still had the 3.6 flash in the ECU in these tests..
The 286HP run was a stage II 3.6 that started life as the bone stock 3.2 that made the lowest power on this graph (it was hurting)...
