Old 05-12-2005, 12:22 PM   #3
bigislandboxster
Option code info........
I was recently looking up the same info regarding options on my '98, and I believe the option codes are located when you open the front hood at the top.....There are a bunch of 3 digit codes up there, and I believe the 030 number is the sport suspension designation....Somebody else might want to chime in to confirm this as I am a bit new at all this still
Lou
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
