Old 07-06-2009, 12:06 PM   #2
70Sixter
Your car has a fuel return system which means unused gas goes back to the tank. With MY02s the cars went to a sealed non-return system.
As Randall said, the sending unit and also the pump is in the fuel tank. Could be the sender, but I'd check/replace the (external) fuel filter and inspect the lines for kinks first. A clogged filter will impede fuel distribution. The external pressure regulator could also be a problem.
While it does sound like a vent symptom, I don't know if that is likely in a recirculating system.
Anyone?
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
