Old 06-27-2009, 03:06 PM   #1
derb
Well, it looks like the relay shaft won't pivot back and forth. I popped off the shift cable from it and the gear shift knob moves to all gear positions. Looking at the manual it looks like this shaft controls the forks for 1st, 2nd, 5th and reverse. I can shift to fifth but why not 1, 2 or reverse?
Not sure what I can do now other than have it towed to a shop for their opinion.
Already looked on eBay for used 5-speeds.
Anyone have any experience in repair/rebuilding these transmissions?
JAAY,
Set screw is fine and the cables are locked in place. Since that pivot won't move does that rule out a bad clutch. No warning signs from the clutch-shifting just didn't work after pulling in the garage. Thanks for your post.
As always, any advice is appreciated.
mike
derb is offline   Reply With Quote
