Old 05-08-2005, 11:55 AM   #2
oneyellowboxster
As a followup, I found the plastic base that holds the recepticle and receives the headlight 7 blade plug had cracked. It was not allowing all the blades to make contact. A little epoxy and the problem was solved. Thanks again to donv for pointing me in the right direction.
oneyellowboxster is offline   Reply With Quote
