Originally Posted by Topless
Looks like wiring issues. Rodent damage or heat damage between your sensors and DME. Give it a look.
OK. I'm going to pop the trunk cover and check the wiring today. Someone else suggested resetting the DME/ECU by disconnecting the battery for 15 mins? About the O2 sensors... If I decide to pull the trigger and replace all four, are they all the same? I've seen them as low as about $80 on eBay but the info seems inconsistent on wether the ahead/behind catalytic converter are the same sensors. Thanx!
