Old 06-22-2009, 09:49 AM   #5
Thumper
Thumper's Avatar
Once you've pulled the switch button off of the emergency flasher, taken out the screw behind it and behind the microphone cover, then you have to lift the cluster up and get to the emergency flasher connector from behind the cluster/pod. There is a tab on the connector that you push in while pulling back on it. It's been awhile since I've done this, but I'm pretty sure that's correct. I believe that this is addressed in the link I provided earlier.
Thumper is offline   Reply With Quote
