Old 06-15-2009, 02:29 PM   #2
Lucky
Originally Posted by Brad Roberts
The key is: they will work for people who never track their car or autoX it.
Yup... I just use the Boxster as a street car, so I'm not worrying about breaking these. Up to about 500 miles... no rattles, yet.
The one weak area, in my opinion, with the Design911 links is the spacers. They have very thin walls, so the clamping load that is transferred between the spacer and the hub carrier (at the upper end) or sway bar (at the lower end) is concentrated in a small area. My concern is that this concentrated load will cause wear or deformation to the mild steel sway bar or soft aluminum hub carrier. Having said that, I have experienced no issues yet.
BTW, I started this thread to share this experiment with y'all. If it turns out well and these are durable links... then great. If, after a few hundred more miles, the parts go sour then that is an acceptable outcome as well. We all get a chance to learn from my (poor) choice, then. I'll report back as the miles grow.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
