Old 06-12-2009, 10:49 AM   #3
AWay
Send a message via AIM to AWay
Originally Posted by blue2000s
There might be one of a few things going on with your shifter.
1. Shift action becomes more difficult when the front motor mount deteriorates due to cable routing.
2. The 2nd gear syncro on our transmissions has a tenancy to wear out. The gears will tend to grind a little going into second, especially cold, or will even pop out in extreme cases.
3. The bushings in the shift lever wear out, making the shift action "sloppy". The new shifter will fix this.
Nice info regarding the motor mount. I wasn't aware of that. It definitely feels "grindy" going into 2nd and oddly enough 2nd gear has popped out twice now... This isn't sounding good for me. Are either of those two items easily replaceable? The motor mount sounds it, but the synchro does not.
Oh and I ordered the 997 shifter just now as well.
AWay is offline   Reply With Quote
