Old 05-04-2005, 03:39 PM   #1
jfmillr
jfmillr's Avatar
Both of those codes are from your O2 sensors on your exhaust. The front two right off of the first set of CATs and near the headers. I had the same problem for a little while, but I have a VERY modified exhaust. if you are still on your stock exhaust system then I would suggest replacing both of those O2 sensors and have the codes cleared from memory and you should be ok.
www.09860.com
jfmillr is offline   Reply With Quote
