Old 06-07-2009, 05:57 AM   #1
986FortyEight
Originally Posted by Lucky
If it is a recent tear and there is still plenty of good grease in the ball joint, then you can simply patch up the tear with some rubber cement. You'll get many more years of service out of the joint once the boot is patched. If it were my car, I'd patch the tear and not think twice about it. A bicycle tube repair kit should be all you need to do the fix.
As far as replacement goes, I believe the ball joints are pressed in and require special tools to remove and refit new joints. Not something you can do in your home garage.
You can buy rebuilt control arms now for a good price (<$150). Factory new replacements are around $300.
thanks Lucky!. Sounds like a good idea. Fortunately, a true family of Porsche enthusiats lives down the road from me and since all their boxsters are spec with GT3 control arms I was able to buy one of their old standard ones for $50 (they are really nice).
Meanwhile I found that according to the bentley the boot is not serviceable and the whole arm must be replaced.
I will feel better around the track with a clean boot.
Mike
Michael
http://imgur.com/aiZcIk8
986FortyEight is offline   Reply With Quote
