Old 05-09-2003, 05:39 AM   #2
Tool Pants
The specifications are in your owners manual. You have you remove the metal plate that is shaped like a triangle to get to the drain plug. You also need the correct allen wrench/bit to remove the fill plug, and a special anti-tamper triple square bit to remove the drain plug. I happen to have these bits. Jeff
Tool Pants is offline   Reply With Quote
