Old 05-30-2009, 05:30 AM   #1
eightsandaces
The cat delete is certainly a contributing factor to the sound. The muffler "hack" can be searched in the performance threads. I thought I read one set of cats could be deleted without causing a failure at inspection. I would want to make sure of that, also if you drive at all with the top up you should consider whether permanent loud is really what you want.
eightsandaces is offline   Reply With Quote
