Pad wear indicator light on??
This is the closest thread I could find related to my issue. I just replaced my brake pads in fact I replaced EVERYTHING related to brakes (rotors, pads rebuilt calipers and new hardware). I replaced the old wear indicators (which fell apart when I removed them from the pads) with new indicators. Not OEM but Pelican Parts told me they were the same as OEM in fact manufaxtured by the same supplier. The look identical to the old ones. Took the car out after reassembling everything to bed the new pads in. Everything went well except my pad wear indicator light came on? Any suggestions? Trying to sell the car so I can't have any lights on the dash. HELP!
Originally Posted by MNBoxster
Hi,
Very possibly water in the connectors (1 or all). Unplug them and blow dry w/ compressed air, that should do it. If not, check for split insulation on the wire and/or for broken wire (though if the problem's intermittent they're probably OK). Hope this helps...
Happy Motoring!... Jim'99
2004 Porsche Boxster S
Portland, Maine
