Old 05-11-2009, 05:18 AM   #2
eightsandaces
One option would be to locate a replacement front of the same color from a wreck. If you can find one, which admittedly might take some time, you could simply remove the bumper cover, clean the radiators while you're there, and replace the piece. You could also, upgrade to a different front end or have a stock BC of a different color resprayed, both higher cost options.
IMO, I doubt you will press those out without creating some spider cracking, if you decide to attempt repair, I would definitely remove the cover, then you can work with the piece from both sides.
eightsandaces is offline   Reply With Quote
