Old 05-06-2009, 07:13 AM   #10
rick3000
There Is No Substitute.
rick3000's Avatar
Originally Posted by schoir
BTW, if you wanted to stick with your old style transmissions (which is not what I have chosen to do), I don't see why you wouldn't be able to swap in the new '03-'04 glass top and frame in place of your '99 top and frame and have it work the same way that the old top worked.
Could you elaborate on this? So why bother changing the transmission if it may work without changing anything?
Also, what sort of cost are you looking at in addition to the top, to retrofit the '03-'04 top to a pre'-00 the way you are going to do it?
Thanks!
