Old 05-05-2009, 07:40 PM   #11
Boxtaboy
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by rick3000
GAHH lists the '97-'02 glass upgrade top as having a window that is 35.5" x 12". Can someone measure the '03-'04 glass window? I am curious to see how much larger it actually is, may determine wether it's worth doing.
I can measure for you next time I go to my garage, but I don't think the main appeal of the 03-04 window is the size of the window. I think the main appeal is that it doesn't limit engine access, with the larger glass area and OEM fit/look as secondary. As for whether or not worth doing, I think that's a function of what price you can source it for...if found at similar to price of GAHH or a few hundred higher, I think it's a no brainer. If much higher, then maybe not.
Another thing is that it is actually a lot easier to just swap the entire top frame than stripping off your old top from the frame and installing a GAHH over the old frame. That would usually take at least twice the time to do vs. just swapping out a top frame. The exception would be if you had a pre-2000 model, in which case you'd also have to modify your top relay/transmission set up.
