Old 05-03-2009, 06:06 PM   #2
cnavarro
I'm assuming if it got that hot, you probably overheated the engine pretty bad. You'll likely want to do an oil change too and probably do a compression and leakdown test to make sure you didn't compromise the engine. What did the temperature gauge read through all of this? Did it leak out all its coolant?
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
cnavarro is offline   Reply With Quote
