Old 05-03-2009, 10:18 AM   #1
rick3000
There Is No Substitute.
rick3000's Avatar
That cable is going to make it more difficult. Unless you want to replace the cable, the best solution would be to use a ground loop isolator that you can splice onto the power and ground wires. They are not very common, but I have seen them at PepBoys. Some isolators work better than others, so I am not sure how well this type will work.
