Originally Posted by mikefocke
at least the 986 versions. I've had 2 of them on each of my Boxsters.
The first set I found was actually convex in shape. The second set had two panels, the outboard one slanted more to cover the blind spot.
They mount by you just pulling the current mirror out of the socket where it mounts and then unclipping the heater cord, then clipping to the new mirror and pressing it in to the socket.
I wouldn't drive a Boxster without this blind spot coverage. And the nice thing about the Porsche asymmetric mirrors are they are completely stock looking and acting plus you get the wide angle coverage you need..
Mike, which set did you like better, between the set that was convex in shape, and the set that had two panels? Are both still offered?
Also, did you run the mirrors on both driver and passenger side? I've read that some people like them better on only the driver side and not so much for the passenger side. How do you feel about this?
Thanks in advance!
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
