Old 04-08-2009, 08:51 AM   #12
renzop
Could we change the title of this thread to "uninformed opinions maquerading as facts about IMS failures"?
Lugging and almost stalling an engine are not the same thing! Wear to cylinder walls, main bearings, piston rings, etc. does not cause IMS failure therefore arguments that state that high RPM causes wear miss the point.
There was one post early on that tried to give a reasonable (although theoretically only) explanation that links low RPM, variocam and additional force to the IMS that sounded like a good argument for staying on the high side of the variocam switch over point. But that is just a promising theory. Jake Raby's anecdotal evidence that one seriously beaten engine has not had IMS failure supports the theory but certainly does not prove it.
I like the idea of driving your car the way you want and not worrying about IMS. If it blows up then either warranty fixes it, you sell the hulk, or pay Jake. Simple and stress free solution.
renzop is offline   Reply With Quote
