Old 03-30-2009, 11:56 AM   #6
insite
Originally Posted by tholyoak
I helped a guy on Renntech do just this. You can use the cable throttle body but you want one from a 3.4, the 2.5 one is too small. Then just treat the motor like a 3.4, use the 3.4 program in the 5.2.2 DME etc. No you can't use the later 3.2. As mentioned by Blue-S, the later PWM adjustment on the variocam is not compatible with the earlier DME without custom programming.
so that means an '02 or earlier? good deal. Todd - can you still program the DME's?
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
