Thread: Timing question
Old 03-29-2009, 07:44 AM   #1
suburban99
Timing question
I have been fighting a PO341 code and missfire codes for bank 1. I removed the cam cover again yesterday and found that the timing appears to be 1/2 link out. I set the engine to TDC cyl1 and the dots on the camshaft line up with the bright links on 1 cam only, the other cam is 1/2 link out. I recently changed the varia cam solenoid as it was not working and unfortunetly did not notice the timing was out.
Hopefully the malfunctioning solenoid was the cause.??
suburban99 is offline   Reply With Quote
