Old 03-28-2009, 05:14 PM   #1
rob76turbo
Alarm question - Alarm remote not locking car
Hi all,
I recently purchased my 01 S and the PO had a lot of work done prior to me buying it. One of the things the shop did was to replace the alarm control module and reprogram. So far...no problems. Doors / trucks opened / unlocked properly.
Today I replaced the battery in the key / remote today and went to unlock the doors. The doors did not unlock and the front / rear trunks did not open.
I used the key to unlock the door and after about 20 seconds the alarm went off. I used the key to start the car and the alarm stopped. However I also noticed that the lock light was illuminated on the dash.
I have tried several more times to use the fob and nothing happens.
Any ideas or things I should try? I remember on some car I had a long time ago, that when you replaced the battery in the remote, you had to go through a procedure for your remote to relearn it's codes. Is this the case with the Boxster?
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
