Old 03-25-2009, 05:30 PM   #7
rob76turbo
Jake, please keep us posted when you finalize this mod!
Originally Posted by Jake Raby
The real solution is our accusump accumulator kit, coupled to the deep sump (ours has a pick up tube extension) as well as adding the sump baffles...
We have made our own version of the X 51 oil pan and almost have it ready to market, its being tested next week for the final time... All these are DIY components that make the engine more resilient to starvation that leads to most all track failures.
Overfilling can cause other issues and reduces performance due to windage.
Please let us know when it is available and how much. Is this something we can do next time we change the oil? I know that we have to drop the oil pan, but I am wondering how much is involved. On the 968 for instance (and yes it is a front engined car...), you have to take out the steering rack, remove the sways, undo the motor mounts, take off the front suspension pick-up points, take out the engine brace (and brace the engine from above...). It is a lot of work to get to the oil pan.
Thanks,
rlt
rob76turbo
Current Porsches: 2002 Boxster S (Speed yellow)
Past Porsches: 1972 914, 1987 944S, 1976 930, 1986 951, 1999 986, 1992 968, 2001 986 S, 2006 Cayman S, 1986 951 track car, 2001 986 S, 2005 Cayenne
rob76turbo is offline   Reply With Quote
