			I have the 3M clear bra on my 05 in Atlas Gray.  It is nearly invisible, you only can see it 5' from the car at certain angles.  It performs as advertised.
 There are negatives.  Waxing the car takes car at the clear bra edges.  Wax can get caught there, and it creates a white line outlining the bra.  If you do not carefully remove, you could force the wax under the bra.
 THe other negative is on the side view mirrors.  On one mirror, the bra edges have lifted maybe a half a milimeter.  When driving with the windows down over 70 mph, there is some wind whistle from the seam.
 Overall, I would install again, as it has saved my paint from many dozes of stone chips.  Hope this helps
