What was the wear pattern like?
If they were worn mostly on the inside edges, then you might want to reduce the amount of camber in the rear wheels.
If they were worn on the outside and the inside edges, then it might have been under-inflation. If worn more in the middle than the edges, then over inflation.
Were you keeping the tires inflated to spec?
2003 Boxster S
1995 Ferrari F355 Spider
San Francisco, CA
