I just replaced my o2 sensors and from those codes you provided, I can almost certainly guarantee you have a bad sensor. I went to partstrain.com and got all 4 replaced with the USOS-4000 model. They were about 28 bucks each. O2 sensors will eventually die out. It's just something that needs to be replaced when they do. You can DIY real easy. Just use a 22mm open wrench to get them off. You can access any of them by just getting under the car (i.e. you don't need to take off any of the bottom covers). Also, you don't need to replace all of them, but I did just because they were so cheap.
